Battery lite on but Alt & batts tested OK
Are there any other things to check on my own before paying the piper again? The battery lite does go off sometimes but always comes back on. Most of the posts in the archives indicated the alternator but mine is fairly recent and tests well. I have two new Optima batts that also test out perfectly.
on
The 2 small wires coming off the same quick disconnect plug will sometimes rub on the altenator housing, down about 1&1/2" from the connector.. My battery lite was coming on and going off and the green wire rubbed thru the insulation.. It was very hard to see.. Had to use a magnifying glass to see the bare copper.. These wires are abit too short coming out of the wire harness.. Reinsulated the wires and it has been good ever since..
Also, check the main wire harness that goes over the driver side valve cover.. These will also rub causing shorts.. Take a mirror and look under the wire harness..
on
Nothing yet discovered
Originally Posted by clintbonnie
Let us know what you find.. It nice to know what causes some of these problems..
It is strange
Originally Posted by HKusp
I wise man here once said something to the effect of: "Automobiles don't fix themselves." Keep an eye out, the problem will return. I can almost guarantee it.
Bringing this post back up becuase it is exactly what I am going through. Alt is one year old, batts are 6 months old motorcraft. Batts test good, alt is putting out 14.4, with everything turned on. I have my ohm meter out and am wandering if I can check the voltage regulator in the Alt while it is on the truck? I started another post a while back after I noticed my lights dimming while driving, now I am actually getting the flickering batt light. Also, I have tugged on the serp belt between the alt and top pulley and I can pull the belt up about 1/2 inch, seems tight. Idler tesion is tight.
there are fusible links between the Alt and batts also check the main grounds on the front of the block. There is one of the wires light green red stripe i think that goes directly from the alt to the cluster that drives the light. it goes through 2 connectors getting there. the first is the main one over the valve cover the other is either the top or middle connector in the row of 3 just inboard of the pcm connector.
PM me with your email an ill send ya the wiring diagram
MTDemX - check the glove box light and the underhood light, maybe just pull the bulbs, and see if you still have a drain. They are two fairly common problems, and you won't see the light if it is stuck on (and it will kill the battery), plus it is an easy thing to check.
pullinair - it is difficult to check the regulator while on the truck - the good old days of "full fielding" an alternator are gone. But, if you are putting out 14.4 with everything on, your alt is where it should be. Do like amiller93 says above - check the harness.
Alan - only guy I know can rattle wire colors and pin positions off the top of his head - just toooooo sharp!!
