Cold & Early Morning Clicking ??
After I cranked the engine this morning there was some brief clicking - sounded like maybe under the hood near the master cylinder/steering wheel area. Only lasted about 30 seconds while I sat in the driveway and backed out. I noticed this 2 other times, again on cold mornings - but not a regular basis thing at all. I welcome any thoughts.
could be a combination of the two. But 30sec does seem a little long for oil starvation.
If it is coming from near your master cylinder it is probably the vacuum boost pump. The vacuum is used to operate the airflow for the heater/defroster, as well as engage the SOF 4WD hubs. In cold weather you tend to loose this vacuum sooner while the truck is sitting. The pump just gives a boost when the vacuum gets low. You can also hear the pump kick in while waiting for the glow plugs, before starting the engine. Hearing this occasionally (or more often when cold outside) is normal.
If you begin to hear this every time you start, or repeats often while driving, there's a severe vacuum leak. As a new vehicle that would not likely be a hose, but rather one of the front hubs not fully engaged or disengaged. I discovered that one recently myself!
