08 450
Contact Matt at Spartan Diesel as to the progress of custom tuning, I know he is working on it. Have not heard of anyone else that is having great luck tuning these trucks. Programmers are out for the 6.4L with mixed results. I doubt if your warranty will remain in tact if you pursue the custom tuning.
Originally Posted by team donzi
looking for any idea's for increased fuel economy,hauling heavy load's,up to 20,000lbs.Will anychip's work with this weight?Any idea's
Changing your gears will help a lot. 4.30's and 4.88's are overkill for 20k and under. 3.73's will be plenty and run much lower RPM's which equate to less boost and less fuel used. I pull 18-27k daily with 3.73's and it has no problems with weight or fuel mileage. Delete the DPF when you can put a small programmer on and you should be good to go.
