1976 F100 vacuum diagrams
I have them from 1973 F100's
I doubt the hose routing was much different.
http://i69.photobucket.com/albums/i7...ATemmisons.jpg
Thanks, Mil1ion, this is a good start. My 76 F100 has 3 or 4 more vacuum devices - 3 of which are mounted in the front corner of the intake manifold. It's these ported vacuum switches tube routing that I need information on. BTW, I appreciate you for posting all the great information on photobucket.com. I figure the vacuum tuneup is about 90% complete/correct. The normally open solenoid valve is not back in the circuit. Otherwise, most of the vacuum controls are working as they should. Have posted pics of the vacuum tuneup and engine compartment at
http://community.webshots.com/album/562060088AIowzA?start=0
Emissions test not required but emission controls must be in place. Some inspectors will disregard missing components since testing is not required. But most inspectors will not do inspection if obvious components are missing, like EGR valve, PCV and a few other devices. So, bottom line, we try to keep major emission controls operative and look for the forgiving inspectors.
Need vacuum route diagram or pics for 1976 F100 360FE 4x4 4 speed
1976 F100 360FE 4x4 4speed step side Custom. Need the vacuum route diagram for carb heat flap. Saw this thread but am unable to view the links after I click on them. Here are pics of my progress.
360FE oil bath air cleaner base with carb heat actuator. Various vacuum connections and a pipe connector on side of air cleaner
Top of air cleaner showing two vacuum ports besides the 90 degree pipe connector.
360 FE , 1976 F100 4x4 , 4 speed, power steering pump soon to be reinstalled. Emissions label for rocker cover still needing to locate a source for it D6TE-9C485-APG is number on original label.
D6TE-9C485-APG Emissions label before I restored the rocker cover.
monreal
10-23-2022 09:49 AM
Fordman76t
01-31-2007 12:45 AM
