Has anyone changed the front seal (pump seal) on their C6 transmission? I am changing the flexplate on my 460 and I want to know if I can change the leaking seal while I have the transmission out. I do have one of those crude seal pullers, as well as a set of seal installation tools. I need to know what the procedure might be, as I can't find it in my Chiltons...
Thanks!
Mark
slide torque converter out,pry old seal out of tranny,pound in new one,simple as that.lube up rubber on new seal with atf before sliding t-converter back in to prevent ripping the seal.
It's that easy??? Cool! I dig it!
I will definately pick one up, then! Thanks a bunch.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
