I think I ran a wheel bearing dry on the front end of my 2001 Ford Excursion. Do I need to replace the outer axle stub when I replace the hub/bearing assembly? Where's the least expensive place to buy one?
Been there, done that. Mine was worn .030" due to running on the dry needle bearing.
You can get the stub shaft by itself, though the Ford parts guy won't be able to look it up. Give them this part number:
4C3Z3B387AA
You'll need the U-joint as well:
F81Z3249AA
Fat Boy, I don't. But, I do know the Excursion uses a 50, I was told by the dealer (an apparently very knowledgeable fellow) that this is used on "all Super Duties", and these fits perfectly fine on my '00 X.
Plus, I got that info from another guy with an F-350 ('02, I think) so I'm confident it's a common part for the whole line. - GA
