Do the '02 7.3's have cavitation?
Coolant
Gold (yellowish to me) colored Coolant = no additives required.
Green Coolant = Yes - need to add SCA
Your truck is near the changeover point from green to gold by Ford. If you are still on your original coolant now would be a good time for a flush & refill anyway. So if you have green you could switch to the G-05 (Gold) - just remember to get all of the green out during the flush.
DG
DG
Originally Posted by parkland
Whats it called, i accidentally put the red stuff in last summer...
Need to flush and put in the good stuff....
https://www.ford-trucks.com/forums/6...n-coolant.html
You can get the concentrate at Napa, or Rotella ELC which is the same thing from a local dealer that you can find on their website.
One new thing that occurred to me recently is that if you switch to ELC, you don't need the coolant filter. That's because ELC does not contain any SCAs whatsoever, which is what "drops out" of the liquid making the sand that needs filtered. It's not clear on the Final Charge website, but they tell you to replace the filter with a blank when you swap.
Here is the Final Charge website where you can read all about ELCs:
http://www.finalcharge.com/
And here is Rotella's site on the subject:
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/leftnavs/zzz_lhn2_0_0.html&FC3=/rotella-en/html/iwgen/products/dir_products.html
EDIT: Here is another good site I found. Pretty much cuts to the chase:
http://www.sancarlosradiator.com/antifreeze_coolant.htm
