Tow Capacity - Am I pushing it too far?
There's a few things to keep in mind that the prior posts did not highlight.
I have a 2000 F250 PSD, and the limit for conventional towing (5th wheel tow limits are higher) on mine was (I believe) 10,000#. Your truck would be similar, and perhaps somewhat higher.
However, it isn't the tow limit that's an issue, IMO opinion, but the trailer's tongue weight, together with the payload capacity of the F250, that is one of the things that you should watch.
If your loaded trailer weighs 10,000#, you should make sure that the tongue weight is at least 15%-20% of this loaded weight (don't put that Jeep so far back that it acts like a teter toter, with a lot of the weight behind those trailer axles).
The Payload on your truck is somewhere around 3,000#. That's a critical weight in your case to keep your eyes on. The payload includes everything you load into the truck - passengers, full tank of gas, stuff loaded in the bed, etc., plus the trailer's tongue weight (which alone might be 2,000# of those 3,000# allowed pounds).
Lastly, you may wish to consider getting a sway control and weight distribution hitch, to keep the trailer from swaying as you tow it, and to transfer some of the tongue weight onto your front axle.
That may seem like a bit much to consider, but if you do all of that, and keep your speed under control, you should be okay with that load.
John
John
John
John
Originally Posted by DCSpecial
You run stock height tires or is the truck lifted?
As mentioned 10k isn't hard on the trucks. I tow 10-11k often with my 07 (stock height...stock motor).
Banks on the 6.0 will put down ~365rwhp based on the dyno of one that I saw published.
How much should we reduce the rating for lifted trucks that have the correct gear swaps? I know the increased rolling mass takes a toll but most people ignore it.
Props on your writeups in FOURWHEELER. That Teal-Brute is a good lookin' rig.
Originally Posted by Customz
DC-
Really without an EGT gauge it's hard to set a limit. I know with my 38s and 3.73s my EGTs were about 200-250* higher pre turbo when empty (never towed with that setup though).
Also, trans temp will come into play since you are working the trans harder with the larger tires and the load.
#29
With the F-250, you can get by with a fairly low-end WDH and be fine. That's what I have (don't even know the brand) with my 26' travel trailer, and I don't even have sway bars! Only one trip I wish I would have had them, but with mostly local trips to fairly close campgrounds and such, I haven't justified the need for them yet.
#30
