A good camshaft for this aplication?
Hi, does anyone have an idea of a good camshaft for my new engine?
It´s in a 1970 Mustang. 460cui ,headers, pi-heads,about 9,5:1 comp. ,true roller, torkel II intake, holley 750 vac, 10" converter stall??. C6 trans, shift kit,
9" rear about 3.0:1 ..stock pistons and rods.
street/strip driving.
400-500hp? ET? any ideas?
Mask Sweden
Mask Sweden
With 3.0 gears in the rearend, you may find it difficult to get it to hook no matter what cam you use. If you're running a single plane manifold like the Torker 11, I'd say use a duration that starts the torque/hp curve about 2500-3000rpm, +10 degrees on the exhaust and a stall converter to match. resized/peened stock rods are good for 5500-5800rpm, which is going to be about your max with that c/r. This is a truck site, so for better info I'd try one of the BBF Mustang forums like
http://bbs.hardcore50.com/vbulletin/forumdisplay.php?s=131eccd82faef71939a00f9938f1cad b&forumid=7
