Pesky Check Engine Light (code inside)
Hello
I have a 1999 Ford Ranger with the 4.0 and the automatic transmission. I have an on/off again (mostly on) CEL that reads P1131. The truck runs fine, although it does run rough while in gear and idling from time to time. This is faily rare, but when it does do it the engine is never fully up to operating temp.
I have recently replaced the upper intake gaskets (the rubber figure 8 things) and the fuel rail gasket which fixed code P0171 I was getting. But P1131 just won't go away! EEK!
My truck has 125K on it. Within the last 25K I have replaced the plugs with Motorcraft plugs, the fuel filter, the air filter, the IAC Valve, and the intake and fuel rail gaskets I mentioned earlier.
Can anyone give me some insight on where I should be looking? I don't know where to start. All the definition of my trouble code says is "Lack of Bank 1 O2 transitions- Lean. ECM detected bank 1 O2 is at its lean limit."
Thank You
Chris
Thank You
Chris
brian_06328
10-01-2006 11:59 PM
Firefighter8-1
08-03-2004 08:36 AM
billybob2
1983 - 2012 Ranger & B-Series
01-14-2004 01:05 PM
