Scrapping noise when accelerating
Old Jan 10, 2008 | 09:10 PM
maddhatteraz's Avatar
maddhatteraz
73 302 4x4 truck 4 speed(first is granny gear)
When I am accelerating I hear a scraping, similar to a metal pole being drug across cement. This happens only when accelerating in second and third gear. If I maintain my speed, it does not do this, if I am in 4th and accelerate and am going faster than 35 I do not hear it unless I am pushing the truck more than usual.
The truck drives the same as it always does, just have the noise. its a cotinous noise that does not fluctuate if I maintain a steady increase in speed, if I accelerate more, It gets louder.
Any Ideas?
Old Jan 11, 2008 | 12:14 AM
Dirt racer's Avatar
Dirt racer
Maybe check out your motor mounts
Old Jan 11, 2008 | 01:18 PM
4x4 Bart's Avatar
4x4 Bart
Sounds like bearings, drain your trans and look for evidence in the drained oil
Old Jan 11, 2008 | 01:22 PM
Mil1ion's Avatar
Mil1ion
First gear.... not matter what vehicle it is in has ALWAYS been considered GRANNY Gear
It is only a slang term for going slow like an old lady would in her sunday drive.
Old Jan 13, 2008 | 01:14 AM
Slag-hammer's Avatar
Slag-hammer
Amazing maddhatteraz! I'm having a very similar problem on my 428 auto. Just as you describe, when accelerating. What direction do you think the noise is coming from? Engine?, Tranny? Left? Right? I've looked at loose starter bendix cover or starter heat shied rattling against headers. It even sounds a little like very loud valve rattle, but as you say, truck continues to run fine with no change.
Old Jan 13, 2008 | 01:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Does your truck have a two piece driveshaft?
Possibly a bad "carrier bearing" inside the 'Driveshaft Center Support.'
D9TZ-4800-A .. D/S Center Support Kit
Fits all F100/150's and some F250's from 1957 thru the 1990's.
The bearing inside diameter is: 1.37"
Old Jan 13, 2008 | 04:21 AM
m78's Avatar
m78
If you have the 2 piece drive shaft, theres a dust shield on the driveshaft in front of the carrier bearing that can rub the carrier when torqued .It can simply be bent away a little bit. When it rubs it makes the whole drive shaft ring loud.
queen of spades
Mar 11, 2015 09:36 AM
Kaw-Liga
Nov 4, 2014 09:08 PM
SolidCitizen94
Nov 20, 2013 09:14 AM
wlhale
1997 - 2003 F150
17
May 7, 2000 02:36 PM
