OE Tires and Towing w/ Expedition EL
Took the plunge and traded my Excursion for an Expy EL... love it so far (but miss some of the space). In an earlier post I asked what people thought about their towing experiences with the EL, and now that I have one with the 18" wheels I've got a concern...
My rig has the heavy duty tow package and is rated at 8750lbs (subjective, I know). My concern stems from the original equipment tires (255/70-18 Pirelli STR A, P-Metric) and the fact that I've got a 7000lb 30' travel trailer to pull on those tires. With 2470lb load capacity on each corner and a rig that weighs, say, 6250, plus 500lbs of gear/people/dogs, plus 800lbs tongue weight I'm under the GVWR / GCWR / max tongue weight (w/ equilizer and sway hitch), etc... and I'm within the load carrying capability of the tires, but am I going to have a wishy-washy dangerous mess going down the road on these tires? Its not the weight I'm worried about necessarily, its how well the sidewalls will hold up to the heavy side-to-side forces. Long, tall trailers can even be a challenge for the bigger Excursion with E-load rated tires.
Thoughts... experiences?!?
Thanks in advance!!!
I have Bridgestone Dueler AT Revo tires that are load rated to 2535 each and have a 6000lb + trailer load and full load of people, gear, etc. in my 97 Expy on a regular basis. Never had a problem with tire (or any other) stability. I do tow with a WD hitch though, which I would highly recommend.
The Expy EL (extended length) is no Excursion but it has some whiz bang auto stability control gizmo's that should help keep things at bay...some.
The P rated tires should likely be aired up to their max allowable on the sidewalls to help stiffen them from a 'flex' standpoint but if you feel some instability in handling due to the higher pressures...be prepared to back off in 5psi increments up to the NEEDED psi for the actual load.
If you find the 'wishy-washy' feeling won't go away even though you have things verified at a scale that your tongue load is between 10-15% and better yet at 12-13%...you may still need to look for a higher end hitch like the Hensley Arrow or new ProPride. Both use a virtual pivot point projection geometry that virtually eliminates sway. They are pricey new ($2500 for ProPride and $2800-3000 for Hensley) BUT they are much less expensive than trading your new EL for something else.
I've read good things about the EL but it is still a full independent 1/2 ton suspension with P rated tires which may need some help to 'stabilize' the setup.
Just my random thoughts here...
Good luck and take the setup to the scales to be sure what load you actually have on those axles and tires...also that will ensure that your tongue load is properly balanced as well as your WD shifting the proper load BACK to the front axle. If you have any questions on what weights you need to take...just ask...3 simple weights will give you all the info you need. Likely less than $10 total at the scale.
joe.
joe.
All I can say is take the time hook it up & go for a drive. Just see what & how it feels. Heck load up the trailer, kids, wife & cruise around town out on the highway, stop & fix lunch out on your drive. Just act like your going on vacation some Saturday. Nothing like towing it to determine how it & you feel about the whole thing.
Originally Posted by grafekie
Eeek... sounds fun. That reminds me... my trailer is already due for its first bearing repacking! Has it been a year already?
Gman22Expy
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
20
05-24-2022 03:47 PM
clearnetedm
09-14-2009 06:19 AM
Chris89lx
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
18
03-27-2009 04:12 PM
