So with a 2" inch leveling, will the 325 65 18's fit on the stock wheels with no rubbing issues?
Wow, 9 month old thread revived!
As I posted earlier, that size tire will be tight with just a leveling kit. There are guys that run it with 2.5" AS kits with little rubbing, but the 2" may not be enough. 325 is a very wide tire. I would suggest a 2.5" kit plus 3" rear block for that size, or drop down to the 305-65-18 size range.
ok thanks i've been looking at the nitto terra grapplers. I think i will go with those in the 275 70 18 size. They look good on yours. I have an 04 fx4 supercab.
That 325/60 or 65 is too wide for stock rims, some people have put it on the stock rims just don't see how it will wear right. Stock rims only 7.5 width and I believe that tire recommends 8.5 or 9-11 inch rim. just my .02... I'm going with the new mickey thompson atz 305/70R18.
Good choice! The Nitto's are basically identical to my Toyo's but with a different sidewall. I like the 275-70 over the 285-65 since there is more of a height bump over stock. The 285's only gain you .5" over stock, and the 275's gain 1.1".
Just joined this site last night and my first post was asking this question. I'm planning on doing a 2.5" lift in the front to level it and I wanted to go up to a 275/70/18 tire but wasn't sure if it would fit. Glad I found this thread! Huge help!
