Steel Rims
Old Jan 9, 2008 | 02:33 PM
cl8ton's Avatar
cl8ton
Cool Steel Rims
OK... I have the famous "gray steel rims" found on most Mazda and Ford Rangers. You know, the ones that do nothing but rust?
I would like to keep these rims instead of spending a ton of money for replacements. So, has anyone had experience painting this style of rim? If so what type of paint was used? Any suggestions would be appreciated.
Thanks!
Old Jan 9, 2008 | 02:41 PM
Conanski's Avatar
Conanski
Sandblast and powdercoat them, or at least have an autobody shop apply some real automotive paint with hardener. I have a set of steel rims for my F150 that were done by a bodyshop and they still look decent 8 years later.
Old Jan 9, 2008 | 02:44 PM
cl8ton's Avatar
cl8ton
Great! Thanks Paul
That's a better suggestion thatn my Brother in Law's. He suggested "Tremclad" but the man works at G.M. in Oshawa so thats gotta tell you something.
Have a Good one!
Old Jan 9, 2008 | 08:59 PM
charliegsstt's Avatar
charliegsstt
I to have 2006 2w drive ranger, would like pick up two spare wheel to mount snow tires on. will older ford truck wheels fit? or would explorer wheels fit? please help me out.
e-mail is charliegsstt@yahoo.com thanks charlie.
Old Jan 9, 2008 | 11:00 PM
Conanski's Avatar
Conanski
Originally Posted by cl8ton
That's a better suggestion than my Brother in Law's. He suggested "Tremclad" but the man works at G.M. in Oshawa so thats gotta tell you something.
Now that's funny right there...
Old Jan 10, 2008 | 01:21 AM
Pablo-UA's Avatar
Pablo-UA
I did mine. Gave them to sandblasters, painted them like usually paint bodies. That is all.
Old Jan 10, 2008 | 05:48 AM
michigan66's Avatar
michigan66
I bought a used steel wheel and cleaned up the rust with rotary wire brushes and sandpaper. Sprayed it first with primer and then Rustoleum Professional High Performance black enamel paint. The wheel has the spare tire mounted on it and hangs under the truck. After a year and a half of Michigan salty winters it still looks good.
Old Jan 10, 2008 | 07:24 AM
cl8ton's Avatar
cl8ton
Thanks for the suggestions guy's... Looks like I have another spring project for the truck
Have a Good one!
Old Jan 10, 2008 | 11:19 AM
5.0B2's Avatar
5.0B2
Another option is POR 15 - kinda expensive though and it takes a special thinner/solvent.
Old Jan 10, 2008 | 11:28 AM
MisterCMK's Avatar
MisterCMK
I second the POR-15. It is some good stuff and your wheels will never rust again after POR-15. One thing to be aware of is that POR-15 requires you to top-coat it if the surface will be exposed to sunlight.
Old Jan 10, 2008 | 11:33 AM
cl8ton's Avatar
cl8ton
Thanks guy's. Will call around about the POR-15 but I take it a professional should use this product?
Old Jan 10, 2008 | 11:39 AM
MisterCMK's Avatar
MisterCMK
Nah. You can use it yourself. You can paint right over the rust that is there, just make sure to remove and loose particles. You can buy it at auto parts stores. www.por15.com
We used it on the 75 Trans Am that we are restoring. We coated the undercarriage, floorpans, sub-frame, control arms, etc with it. None of that stuff will ever rust again.
One thing to be aware of is that the POR-15 will stay on your hands or any clothing if you should spill or make a mess. It also has a nasty strong smell.
Old Jan 10, 2008 | 11:50 AM
cl8ton's Avatar
cl8ton
Thanks Chris
Will check it out
