my 7.3 shutters at 3200 rpm why?
I have a 03 7.3 with a super chip model 1705 stacked with the banks six gun chip that shows me my boost and my trany temp the six gun is made to stack with the super chip i also have a new tranny and air intake the truck only shutters at 3200 rpms if i am getting into it as you probably know that the 7.3 red lines at 3600rpm also you prabably know that the super chip takes the factory rev limter of . so what is going on with my truck i cant figure it out i also change the fuel filter many times due to idea of i might not be getting enough fuel. ANY SUGGESTION ARE WELCOME I AM LOST ON THIS ONE?????
Injector pulse width (on time) is too short at those RPMs and there is insufficient fuel being delivered.
The factory IDM starts cutting back injector on time at high RPM because it is unable to fire 2 injectors at once..and at 3200 RPM and up, the injector on time is quickly approaching the limit......right up to where the next injector needs to fire.
Besides, pushing a powdered-metal connecting rod to those extreme RPMs is just asking for a block window.
Originally Posted by 1996pwrstrk
I run a 6speed and see over 3200 rpm with no problem I would start by returning your tune to the stock setting and take it for a run and see how she acts, while your hooked up check for codes.
on
1 Post
Originally Posted by Markadeck
Sorry, but I just have to ask. Why in the world would someone want to buzz a 7.3 to 3200 rpm for any extended period in the first place?
I usually run it up to redline every day, usually every shift. I also top it out at 3400 rpm in od usually two or three times a week. The only things I have to say is that when I held it at redline for over ten minutes my water pump started cavitating, so I all most overheated.
Yes my wear metals are high on my oil analysis, but my last truck, which I did the same to, had SPOTLESS oil analysis every time. The wear paterns started in this engine before I ever got around to working it.
thanks for the info guys it only hit that high rpm when it is going from 2 to 3 gear when it hit 3400rpm and then it does it after i flip the speedo and i start to get ing the speedo up to3200rpm the whole truck starts to shake a little bit and that kinda scary when you are doing over a 100 ha ha !!! also i thought that might of just been a rumer about the powder rods instead of the forge steel rod that the older 7.3 rods so when did they change the rods in 03 or was it in late o3 owe yea and my six-gun is set to start defueling at 26 psi of boost but i am not pushing that much boost i am only pushing 24 psi also what is the bst time at the track 1/4 that ya'll are running also when i first bought this truck it never use to shuuter and then it just started gradualy shuttering at high rpms and if i sell the six gun and the superchip what would yall suggest i put on it and if i do have the powder rods what can they handle before the take out my moto thanks for all the info and please continue to give the addvice i need to get this old 444cu inch big block 7.3 running at a respectable pace down the road and the track
