max tire size
Old Jan 6, 2008 | 03:19 PM
Dan Taylor's Avatar
Dan Taylor
max tire size
whats the largest tire i can run on a stock 95 f150 short bed. what would the max size be with the same truck with a 2'' body lift?
Old Jan 6, 2008 | 03:27 PM
dixokai's Avatar
dixokai
I would think you could get 33s under it with a 2" lift. 31s fit pretty good with no lift.
Old Jan 6, 2008 | 03:40 PM
sp metalman's Avatar
sp metalman
The largest I could get under my 94 was a 32/11.50/15 and it will rub if you turn it all the way one way or the other with the lift a 33/12.50/15 would fit nicely but you might get a 35/12.50/15 under it. My advice would be to get some 16in rims you could run a 285/75/16 ( 33/10.50/16 ) this size is what I run under mine with no lift and it does fine . What the problem is with going taller you also go wider on most 15in tires which is why you rub the radius arms on early 90 F150,s so to go taller you have to lift to give clearence thats why I suggested the 16,s they are normally narrower for the same height as the 15in I hope this helps.
Old Feb 13, 2008 | 08:51 PM
bigdog2's Avatar
bigdog2
I have a 2007 F150 XLT what would be a recommended max tire size with no lift? Ihave 17" rims stock on truck.
Old Feb 13, 2008 | 09:16 PM
95F350XL's Avatar
95F350XL
33's will fit on a stock F150/Bronco. I had to trim the inner bumper lip. On my 95 Bronco. Depending on wheels will/not rub on your radius arm. 2" body Id say 35 should fit. I got 36's on my stock F350. BigDog your in the wrong year section. Umm I did do a set of BFG AT's on ur style at my shop once, but I cant remember the size. It wasnt too much bigger then stock. Whats the size you have now? Id go a size or 2 up from that.
Old Feb 13, 2008 | 09:26 PM
bigdog2's Avatar
bigdog2
Right now I have 235 70 R17 right know. Also looking for a 2" body lift any ideas where I can find one resonably priced? This truck is still under warranty until next year, then I'm going to put different tires on.
Old Feb 13, 2008 | 10:34 PM
bluesman2333's Avatar
bluesman2333
I have 31x10.50 tires with aluminum wheels on a 93 F150 2WD and no lift, nothing rubs.
Old Feb 13, 2008 | 11:43 PM
Noneshere's Avatar
Noneshere
33X12.50"s Will Fit TIGHTLY
33X12.50's are a fairly common size so the price is usualy better.
I have a 3" Body Lift Here and the max I can run is a 35.5
I went with the 33" because of the cost and common availability .
You can fit 33" , They are going to rub the arm and frame ,and you will loose a little turning radius.
If you put MT's on, the "rub" will "grab" . Because of the tread designs claws.
But you can fit 33" bearly .
I still run a factory steel rim . The fat of the 12.50's on an 8" wide rim looks good
Old Feb 14, 2008 | 10:59 AM
Dan Taylor's Avatar
Dan Taylor
right now im thinking of the bf all terrain 33'' 10.5 instead of the 12.5 since i go on the highway alot
Old Feb 14, 2008 | 01:35 PM
95F350XL's Avatar
95F350XL
That 12.5 only measures 10.5. They are never what they say they are. And I like 12.5 on a 10'' wide wheel. I dont like the tire buldge you get, some you do some you dont. As every tire is a different size no matter what it says. I have had a true 31x10.5, and my friends was like like 30x9 and it said 31x10.5. So if you go with a good brand chances are they will be a bit bigger then the cheaper brands. I had a 255/40/17 on my mustang and my new 245/40/17 is wider then the old one.
Old Feb 15, 2008 | 05:08 AM
mike330's Avatar
mike330
I just installed a 2in. body lift and 2in longer front springs, 15x10s w/33x12.5s I had to trim the plastic from the lower bumper, about 1in. I think if you use 8 in wheels it would be no problem.
Old Feb 15, 2008 | 07:55 PM
MisterDave2's Avatar
MisterDave2
I have a 95 reg bed 4x4 that I just got a few days ago. there were new 33-12.50-15 Apaches on the back and a smaller junkers on the front. I put some BF T/A 33-12.50,s on the front too and it leveled off real nice and only rubs when you turn heavy, I can live with that and I just need to get used to just where I can turn to. The Apaches really get a bad rap, they don't look bad at all, I'll see how they play out.
Old Feb 15, 2008 | 10:40 PM
spartan117_mc's Avatar
spartan117_mc
thats funny, i just bought a 1990 f150 2wd... and im runnnin 33s with no problem
Leovardo
Mar 22, 2017 08:29 PM
Adesros
2015 - 2020 F150
28
Mar 3, 2017 07:22 AM
james oden
Mar 28, 2016 09:22 PM
Codyaye
Oct 2, 2015 02:57 PM
Freakazoid!
Jun 18, 2005 09:54 AM
