no start prob after fuel pump change
truck died in august, mech fuel pump was bad so was the starter. just fixed it today, jan 1st, mech fuel pump was broke and had no fuel pressure at the shrader valve now it has fuel at the shrader valve, but still won't start, i have no smoke from the tail pipe, its 20 degrees still has summer fuel no additives, has 1/4 tank, ive had the charger on all day and block heater for bout 2 hrs been trying it every 20 min or so, still nothing, any ideas?
As clod as it is I would definately make sure the batts have a good full charge. I could be wrong but its just a suggestion, check the voltage at your GPR. If it is good. Check the glow plugs to see if they are good. In cold weather like you going thru it could be a couple bad glow plugs.
Check HPOP oil level. If the oil is not there to push the fuel out of the injectors, then the fuel pressure won't matter.
Also crack open one of the plugs on the oil pressure rail and see if you are getting oil moving out when you crank. My bet is that after sitting that long you have an oil issue.
Also verify the screen in the fuel bowl. You may have had an algae or something growing in there over the past few months and might now be getting enough fuel flow.
yes have a wait to start light, oil in hpop is full, will check the conections and open an oil line, i was guessing an oil prob, its cold pulled the dipstick and its like honey. if the oil is too thick will it not fire the injectors? and if i plug in the block heater will it warm the oil in the injectors to allow it to flow?
