Starter gear throws out then free spins!!??
iv searched and havent found the exact thing but only SOMETIMES when i start my truck it sounds like the starter gear will throw out towards the flywheel hit it then free spin. it will do that a couple times then finally start. sometimes it will start up fine 10 times in a row then the next time just free spin. anyone have any ideas? i have a 2001 7.3 powerstroke with 148,000 original starter.
Interesting how it started doing it out of the blue, which leads me to believe the solenoid is not getting enough juice to throw the star gear out, i.e. bad connection or solenoid (which I believe is on the fender and not on the starter)? If you had just put a starter on, I would say it needed to be shimmed or something to get it to line up?
on
1 Post
I had this happen to me november of 06. From what I figured out, the oil leak from the turbo pedistal ran down to the starter and caused the over running clutch (the one that lets the tooth freewheel once the engine starts) to slip to the point where it wouldnt even turn the engine. It had the most problems when it was cold, and finally on black friday it crapped out on me. Had to plug the truck in and wait 3 hours till I could start it. Let me tell you how much fun it is to change one of these starters when its 20 with 30mph winds.
I put an AZ Duralast starter in that has the lifetime warranty. You'll be amazed how much faster the engine starts with a new one.
Sounds like you need a new starter solenoid. There is an electrical winding to "pull in" the shaft, on a lever system which then pushes out the starter pinion. Then there is a "hold-in" winding that holds the shaft in, holding the pinion out until you release the current. Sounds like the hold-in winding is going bad, and when its not acting up, the pinion throws out and then maintains a constant load on the teeth so they don't pull back in. Sometimes it may not engage (mesh) and click.
alright thanks guys im jus gonna get a new starter. haulinboat you might be on to something there cause i have been waiting for the tranny to go cause its been doin this wierd thing in reverse when i put it in reverse it feels like the tc is trying to lock up and it bogs the motor down? dont know if that has something to do with line pressure or not but i think the tranny is on its way out.
