Hutch mod good, harpoon mod not so good
I did the ITP in-tank kit and there is a noticable diffrerence in the clacking and overall noise. I would definatly recommend spending $ and a few hours on it. When I went to reinstall the modified pickup assembly (same lenght as before) I noticed that it contacts the floor of the tank and is 1/4 too tall to seat the gasket. The foot had a bend to it and it was clear that it was smashed in tight from the factory.
I never had problems filling the top of the tank, but I do now AFTER I cut the fill and fill vent tubes acording to the ITP/guzzle's instructions. anything over half full clicks off the pump at full flow. I can hear the foam come up the fill tube and shut off the nozzle. same station/pump as before. So I basically F-up my tank and have to babysit the last 12 gallons.
Now the fuel bowl drain is leaking too, must be murphy's law.
The screen and tank were very clean. I was hoping to find a clog that would expain my low boost, low EGT. nope.
on
only one reason i can think of for not filling faster..is the fill pipe might not be back the way it came out or got pinched...or the vent is pinched...there is no other way it could be slowed down like that...also screen hitting the bottom of the tank will slow the flow down in the feed line...
Also, the middle of a full tank of fuel will sag a little, so if it makes contact with the tank flat on the concrete it's probably about right. However, you should not have to force it into the tank.
I agree with Ron. It sounds like the fill tube is pinched. Possibly where it goes over the frame.
I inspected the rubber hoses over the frame, they looked fine. Got the drain leak fixed with new o-rings. the yellow coating on the factory o-rings came off and was probaly the cause of the problem. I also re-installed a fuel pressure guage on the cowl to see if I can diagnose my fuel problem(s).
The only thing I would add to the in-tank instructions would be to support the tank on 2x4s at the strap locations.
Originally Posted by dieseloholic
I'm getting ready to do both of these so if you've found something I need to pay attention to please post it. Sorry about the trouble you're having.
Finally, do not drop the new filter assembly on your face. It CAN chip a tooth and give you a fat lip.
I am, when I was installing the FASS pump, the socket "slipped" off the bolt, and I had a mouth full of ratchet. I was on the creeper, and almost, ALMOST, raised my head up to meet the frame rail.
Originally Posted by ron's power stoke
what was the problem? glad you got it fixed and running well.. inj must be quiter ??
