Fog/driving Light Bulbs
Old 01-04-2008, 08:53 AM
brian42's Avatar
brian42
brian42 is online now
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
Question Fog/driving Light Bulbs
I just replaced my headlight bulbs with Silverstar Ultras (wow do I need the headlight harness upgrade now, but that's another story). I know the bulbs are 9007. I was looking at my fog/driving (which one are they?) lights and noticed that the bulb looks like it's replaceable. Does anybody know if they are a sealed unit or if the bulb is replaceable? If so what size bulb is this. I just noticed this last night and haven't had a chance to climb under there and try and look so I figure I'd ask.
Thanks for any info.
Old 01-04-2008, 11:27 AM
wlihntr's Avatar
wlihntr
wlihntr is offline
wlihntr has a good reputation on FTE.wlihntr has a good reputation on FTE.
yes they are replaceable, they are a 899/9145 (pretty sure those are the correct numbers) and are 42 watt. however a 9005 65 watt bulb will plug right in and work better. i have had the 9005 silverstars in my fogs for years...works great
Old 01-04-2008, 05:15 PM
cookie88's Avatar
cookie88
cookie88 is offline
cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.cookie88 has a spectacular reputation.
Yep. The 9005 silverstars will wake those fog lights right up.....but you will probably need to adjust them down a little bit. The 9005's don't have painted ends like the 9007's and seem to be extremely annoying to oncoming traffic.
Old 01-04-2008, 06:16 PM
DaveWilliams's Avatar
DaveWilliams
DaveWilliams is offline
DaveWilliams is gaining momentum as a positive member of FTE.
Question Are they adjustable?
I don't remember any adjustments on the fog lights. Is there one that I am missing? Also I talked to the guy at Brite Box and he told me that it may heat up too much to put anything other than the stock bulbs in the fogs.....I like to run the fogs all the time and figured he knew what he was talking about....What has been your experience with the hotter bulbs? Have you had any problems burning the out or having any housing heat problems? Thanks for the info..Dave
Old 01-04-2008, 06:29 PM
randomhero1172
randomhero1172 is offline
randomhero1172 has a good reputation on FTE.randomhero1172 has a good reputation on FTE.
I have never heard of excess heat - and if you do have that you will smell it on idle. I had a fog come loose and started touching the radiator and it reeked like all hell.
So headlights - 9007
Fogs - 9005
Ive changed the fogs - afterwards my hands were free of all skin lol. Is it a pain in the butt to change the headlamps?
Also - what is the top of the line bulb by sylvania?
Old 01-05-2008, 01:40 AM
jtharvey's Avatar
jtharvey
jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
They have a new Silverstar out called the Silverstar Ultra that is supposed to be brighter than the original Silverstar. When mine burn out, I'll be using the Ultra bulbs.
Old 01-05-2008, 06:27 AM
DaveWilliams
Do they have that nasty blue tint? I absolutely HATE that coming at me or in my mirrors. I won't install them cause I don't want someone hitting me head on when they go blind.....
Old 01-05-2008, 09:44 AM
rjmay's Avatar
rjmay
rjmay is offline
rjmay is starting off with a positive reputation.
I have had the 9005 SilverStars in my fog lights for two years and have not detected excess heat.
Old 01-05-2008, 11:15 PM
cookie88's Avatar
cookie88
cookie88 is offline
I've had the same set of silverstars in my fogs since 2002. Excess heat is a non issue.
Yes they are adjustable, but the adjustment screws are difficult to find and even tougher to reach. Plan on loosing a little skin off the back of your hands.
Old 01-05-2008, 11:21 PM
DaveWilliams
Adjustment screw??
Got any suggestions on finding the adjustment screw? Looking at the light from the front of the truck....look left or right...top or bottom....toward the rear of the truck or the front? I don't remember any screws at all when I had a foglight in my hand after one got replaced...Thanks for any update...
Old 01-06-2008, 01:20 AM
jtharvey's Avatar
jtharvey
jtharvey is offline
Scott, both of my fogs burned out within a week of each other, 9Silverstar 005's, after probably 6 months. I am feeding my fogs with 12 ga wire though, so I don't know if that puts a little extra stress on them or not.
Dave, the adjustment screw is on the bottom of the fog, directly in the middle. It can ony adjust up-down. You may not be able to access it very easily with the bumper still on, but if you zip the 4 bolts out and remove the bumper to get a better look at the lights, the screws should be easily found.
Old 01-06-2008, 01:34 AM
wlihntr's Avatar
wlihntr
wlihntr is offline
huh...i have had mine in for 5-6 years as well with no problems.
Old 01-06-2008, 02:11 AM
jtharvey's Avatar
jtharvey
jtharvey is offline
Luck of the draw perhaps. Hopefully the set I have now will last quite a bit longer.
Old 01-06-2008, 09:37 AM
dvfd12's Avatar
dvfd12
dvfd12 is offline
dvfd12 is starting off with a positive reputation.
I have the Silverstar headlamps, but haven't upgraded my fog lights yet. I like the headlamps, but they have been lasting anywhere from 6 months to a year (kind of short in my opinion). I am using the upgraded wiring harness and have noticed when I change bulbs that the glass is actually melted and deformed. I don't plan on switching to a different brand, just wondering if anyone else has noticed the same thing?
Old 01-06-2008, 09:43 AM
DaveWilliams
That is what I was told would happen because of the excessive heat, that is why I haven't switched to them and switched to them in the fogs as well. I still haven't heard whether they have that nasty blue tint or not...
Quick Reply: Fog/driving Light Bulbs
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
