What octane would I need with 10.1:1 compression ratio in a 460?
I know this is a tough question, but any ideas would help.
I'm trying to build something similair to the edlebrock engine:
http://www.edelbrock.com/automotive/7166pp.html
The main difference being that I'm keeping the stock iron heads D3VE) and using cheaper pistons.
Using Keith-Black-137 flat top pistons I can get a piston to head clearance of .04" (ideal for preventing knock), but if the D3VE heads have a 92 cc combustion chamber, then my CR is 10.1:1
I would like to avoid having to buy premium gas.
Thanks,
Brian
Thanks,
Brian
When that engine came out Service Stations pumped 98 Octane some even higher.
When I feel like spoiling my truck,I mix some AV-Gas (112 Oc)with premium pump gas (91-92 Oc)
Dennis
F.T.E. Assistant Administrator
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Dennis
[font color=red]
You'll need to run premium. Some people feel .004 is a lot of deck clearance on a performance engine. The closer you get to a zero deck, the better quench provided and the less the engine is prone to detonation. .002 or .003 would be good and still leave a little for any future clean-up. May not sound like much, but it does make a difference.
Have you cc'd your heads? The D3s are often 96-97cc chambers. Most shops will cc a chamber for $25 and that could make a difference in your c/r calculation.
93 octane wouls be better. If you want to run the timing slower and lose some power, then you may get by with the cheaper stuff. Between 9 to 9.5 max is about the most that you can run on 87 octane. If you run it a little rich, it may help keep the detonation down too.
>460?
>engine:
>is 10.1:1
>Thanks,
>Brian
I have the D3VE heads and have the KB137 pistons and I definetly have to run premium gas.
>460?
>engine:
>is 10.1:1
>Thanks,
>Brian
BigBlocker0248
06-28-2015 05:47 PM
Highboy74
02-06-2011 08:21 PM
Tsaven Nava
38
07-08-2004 10:26 PM
76f1390
21
02-11-2004 12:26 AM
satx77stepside
11-10-2003 07:25 PM
