Oil on ICP sensor
Oil on ICP sensor
Pulled my ICP sensor to troubleshoot my idle issue. It had some oil on it. Not leaking anywher I can tell but just some oil on the insert portion of the sensor plug.
Is this a sign I should replace the sensor. I haven't gotten a good/cold start to verify if idle/perf issues could be sensor related but seeing the oil makes me wonder if the sensor is bad and should be replaced.
Thought?
Thought?
From everything I've read on here, that's a sure sign that the ICP is going out. You'll want to replace it.
Edit: Here's one for you on eBay for $60, which is about half of what the dealer charges. Item number 130185291235 if the link below doesn't work. Only 16 hours left in the auction.
http://cgi.ebay.com/ebaymotors/ws/eB...1235%26fvi%3D1
jeepnatv4life
1999 to 2016 Super Duty
09-22-2015 05:48 AM
Firefighter 1406
03-19-2015 07:27 PM
cutlass
28
01-04-2014 11:07 AM
