Code Help
Old Dec 27, 2007 | 12:17 PM
  #31
subford's Avatar
subford
Originally Posted by codyingersoll123
well the whole in the cab and under the hood sounds kind of contradicting? Is it in the cab behind the plastic drivers side kick panel or is it under the hood near the icm or something?
Well it is in the cab behind the plastic drivers side kick panel and metal plate, but it has to be removed through the engine compartment.
You can not get it out from inside the cab.
It will hit the inter fender when you pull it out so it has to be loosened and moved some for clearance.
Old Dec 27, 2007 | 12:25 PM
  #32
danr1's Avatar
danr1
Yea you'll need a stout wood broom handle or a stick of 1x2 or x3 4 or 5 feet long to use to pry the back of the inner plastic fender forward, toward the tire to make enough room to pull the computer the last little bit out of its slot in the firewall.
Using wood saves on the paint, you will have to put a little muscle behind it to do it.
The only alternative is to fully remove the inner fender, you'd have to unbolt and or unplug everything that is mounted on it to do that.
Old Dec 27, 2007 | 12:35 PM
  #33
codyingersoll123's Avatar
codyingersoll123
ok thanks...now I understand.
  #34
subford's Avatar
subford
Make sure you unhook the battery negative cable before unplugging the computer.
Old Dec 27, 2007 | 12:36 PM
  #35
codyingersoll123
thanks all your help is appreciated.
ascaife
1997 - 2003 F150
May 13, 2016 09:20 PM
Barbarosa57
Jan 4, 2015 02:14 PM
e6ug
13
May 25, 2013 10:26 PM
dsphoto
Modular V8 (4.6L, 5.4L)
Oct 7, 2009 09:03 AM
wendal
Computer Chips & Tuners
Jan 29, 2006 12:45 PM
