Which brake booster and master cyl to use?
Hi all,
I have a 1974 crewcab 4x4 that I just put new rebuilt dana 60's on.. The axles have new disks brakes and I was wondering if I should use the old style rebuilt master cylinder and booster? Or is another more desireable booster and master cylinder to use with a disk brake setup? .. I would like to just bolt this setup in without any mods...
Oh, forgot to mention that this is a frame up restoration. cab is still off the frame and at the body shop???
You have to get one that related to your year of truck application.
F100,F250 4x4 ?
The mounting changes though the years.
If it was me I would get the 74 F350 booster and make sure you have the power brake pedal assembly to match.
You can find what you need here.
http://s69.photobucket.com/albums/i7...20Application/
http://s69.photobucket.com/albums/i7...osterchart.jpg
F100,F250 4x4 ?
ok, sounds good to me.. Is there a way to determine which booster I have, ie, numbers on the unit?? ect.
I understand there are a lot of variables here.. so, I am trying to stay with in the 1974 f250 series.. I just wanted to get something that would be able to handle disk brakes with ease.
well, from what I can tell, the booster had the vacum line attached and when I drove it it seemed to have power brakes but, maybe there is a difference between the non power and power brake that I am unaware of.???
I still have the pedal and booster from the old set up.. it seems the booster has a straight push arm that attaches to the lower middle of the brake pedal..
I will look over your links,, Thanks much
