Ive read 15 posts on turbo upgrades... now my question :-)
I bought what looks to be a good used(IE appears to be in working order) Stock GTP38 turbo minus the Pedestal and exhaust outlet flange. I have gone onto Ebay and bought a Non-EBV Pedestal and blank EBPV. I will get the code eliminator as well. So Now I have alot of parts to work with... IE a spare full turbo setup.
The current setup is a 03 F250 2wd 7.3PSD with 92,000 miles.
High flow filter, with metal charge tube... filter soon to be a 6637, Edge tuner on 40 tow, 3.5" down pipe, 4" back, magnaflow kit, Oil cross over line, coolant filter, Aux fuel filter and larger fuel pickup... soon gauges. and soon after reg return kit.
Ok here lies the question:
Given that I have 1 mod read for the turbo... what else would you suggest Considerations are... I have no $ for a brand new turbo... l love the idea of beefing this on up, and want to keep my truck running well for as long as possible, so reliable power is what I'm after. Would a bigger 1.0 housing make sense... I would keep it waste-gated though. It seems the turbo wheel is a bad choice, if one can afford a new turbo hosing? But then you have a much bigger inlet?
I like the idea of stock inlet, new wheel and rebuilt and bal, new outlet housing 1.0 waste gated and the EBV del setup? any thoughts? Anyone know a good turbo shop for diesels in Socal Area?
Thank you for any advice... just trying to make my brothers truck what he wanted and not break the bank.
Justin
Justin
Justin
Justin
As for the 1.0 exhaust housing, I'd say yes if you're going to tow a bit. .84 if no.
With in a month or so, my stocker will be rebuilt, non-ebpv pedistal, TN high-flow outlet (no ebpv) and ATS ported shroud (already on there). I tow a TT about 4500 miles a year. Rest of the year is weekend beauty queen to the feed store or whatever.
Hope this helps.
No real towing. Mostly Fwy time and stop light to stop light fun.
The WW seems to caught a 1hp loss or so right? but the the increase in exhaust flow with the EBV gone should balance things out... least I hope. I guess I'll keep the stoke .84 housing then... what about the boost actuator?
Anyone else want to chime in?
I forgot to mention it earlier. I think I will be adding it also.
Ive found some shops in the LA area for a turbo rebuild. Ill have to call around and see if I should get the rebuild kit online and or have it sent out for Bal.
Im thinking stock compressor housing, wicked wheel, Bal, Everything tanked and cleaned, new bearing and o-rings and install of the EBV deleted outlet and blank EBV pedestal, maybe a better waste gate actuator?.... For me upgrades, and cleanup and rebuild are of eq. import. God I love a clean motor :-).
Justin
Justin
Originally Posted by Orezona
Me again, but I've heard good things about this http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=457
I don't know how well they would work for our application, but unless someone has tried it with deffinate negitives, it might be nice to try.
Originally Posted by sneak
Yeah, thats a premade version of a mechanical boost controller. Priced much too high, we use them on DSM's, little 2.0 L turbo car. We usually just make them ourselves. It just takes a few parts from the parts store, and some know how.
xbox73
05-05-2014 06:47 PM
BadDogKuzz
04-16-2012 11:13 PM
