Sponsored by: Real Truck
Front door weather strip
Old Dec 23, 2007 | 04:18 PM
dd4's Avatar
dd4
The front door weather strip (along the top) pulled off after the last freezing rain. There doesn't seem to be any adhesive used behind the weather strip, should there be? thank you.
Old Dec 23, 2007 | 04:36 PM
F250tuff's Avatar
F250tuff
It looks like mine doesn't have any on it. I can pull it out, then push it back in. Some clear silicone might be helpful to keep it in place. You can also put something on the surface to keep it from sticking to the door. I've used Vaseline in the past, but some claim that the petroleum base in Vaseline will cause the rubber to dry-rot and crack.
Old Dec 23, 2007 | 04:51 PM
68 351 bronc's Avatar
68 351 bronc
There should be adhesive but that doesn't mean there was from the factory. Silicone won't hold. Go to any good auto parts store and buy good weather strip adhesive. Permatex makes good stuff in back and yellow. The yellow is ugly but works the best in my opinion.
Old Dec 23, 2007 | 07:09 PM
bedwards's Avatar
bedwards
There is no adhesive on mine. Its just a friction fit.
be
Old Dec 23, 2007 | 09:02 PM
riggz's Avatar
riggz
no adhesive on my 04's weatherstrip.
Old Dec 23, 2007 | 09:24 PM
UP_There's Avatar
UP_There
none on mine.....although the stripping on the front and rear doors on the bottom has come loose several times. Cheap interior crap!
