P0603 Code with additional issues?
Old Dec 19, 2007 | 03:54 PM
user 843678's Avatar
user 843678
I understand the usual cause for the infamous P0603 code is due to having a tuner in use and they trip this "Keep Alive Memory" (KAM) code.
I have a tuner on my truck and have enjoyed it for weeks now. I have seen this code come and go along with the usual P1000 and P1211 codes. I have seen all of them disappear as well -- which is good.
I keep my programmer/display connected to the ALDL port full time and I use the PID display to show my boost, EOT, EGT's etc. What I noticed recently is that the display goes blank (turns off) while I'm driving and sometimes resets/reboots and the truck seems to run just fine. The other day I was driving around and it just went blank. Until I unplugged it from the ALDL port and re plugged it back in it would have been off. Probably until the next key starting, I imagine.
I am wondering if my PCM really has a bad KAM battery and maybe I need to address it by replacing it -- board level or the whole PCM?
Has anyone experienced this?
Old Jan 1, 2008 | 07:03 PM
toolboxjunky's Avatar
toolboxjunky
keep info coming
i have had similar situations but now display blackout i don't keep my tuner plugged in all time now since i installed gauges but the codes have come and gone i am fighting the mpg bug you hear all kinds of bs on mpg on this forum i get 8-9 pulling 11k toybox 13-14 city and 14-15 highway set on 80 hp setting with a edge tuner swith 4"inch ex stock tires
Old Jan 29, 2008 | 11:03 PM
user 843678
EDGE goes back...
Well, it's now the 29th of January and I made arrangements to send my Edge unit back to PMT Diesel for a credit. I laid the ground work so that PMT wouldn't be stuck with the unit (they graciously offered to take it back, even after 4 months of my woes) so they are definitely a good company to do business with IMHO.
Edge just couldn't respond to my issues.
The latest was a wierd 3-4...4-3...3-4 shifting issue at WOT. It didn't do this as long as I wasn't in the pedal at full WOT. It didn't do this when I had the stock program working for me either.
I have some experience tuning for electronic 4 speed transmissions and to me, clearly, this was a tuning issue. I am considering the SCT Livewire tuner for it's greater tuning capabilities and the fact that I can get some Diesel guru's to offer me custom programs for my combo.
Old Jan 30, 2008 | 11:57 AM
toolboxjunky
are you getting a speed sensor code from trans and if you are it is slipping between 3-4 gears. get ready for a trans job build it right from the start all out!
Old Jan 31, 2008 | 07:28 PM
user 843678
Nope, I'm not getting any codes related to the trans. The trans is not slipping. It's an issue in the tuning making the trans shift up and down, that's all.
lakewood
Apr 5, 2015 01:27 PM
kamaleon
21
Apr 19, 2009 07:39 AM
elee3
Jun 1, 2008 05:42 PM
kawa
Jan 12, 2008 02:13 PM
bhs2869
Feb 4, 2004 01:00 PM
