weak or dead posi rear end
i have a 2006 f-350 4+4. i bought it brand new,ordered it with limited slip.has been back to the dealer 4 times for not workin correctly.i was told by ford that the rear has a low torque brake...20 ft lbs,to allow the clutches to slip,to help releive chatter,and rear end noise,also the high synthetic rear diff, lube is to slippery and not allowing the clutches to bind together. what a my options to correct the nightmare..............do i need to replace the posi unit to get it to work like it should? any info would help
I have the same problem with my 2005. I changed the oil and DID NOT add friction modifier and it still did not help. (apparently not adding friction additive will enable worn clutches to "grab" better, just not in my case) My truck has 124,000 miles and the clutches probably wore out long ago. An oil change is very expensive if you use the Ford stuff and it may not work. My next move is a new clutch pack. If it lasts only a few thousand miles then an Auburn L.S or a detroit Locker.
Not adding the friction modifier will cause the clutch packs to stick not grab better. You would be better off adding extra friction modifier to make the noise go away. New clutch packs will correct the problem for awhile. I added additional modifier and the noise went away and my pos still works fine. It grabs quicker then it did when new but I can live with that.
vanman250
vanman250
Adding friction modifier allows the clutches to slip. On a Ford posi differential there are friction plates and drive plates. The amount of friction modifier added determines the ft/lb breakaway torque anlong with the spring pressure on the plates. I know this b/c I have rebuilt many Ford l/s carriers. The plates need to soak in oil before they are even installed or you will get some serious lockage for about 3 or 4 miles. I think the breakaway tq on l/s needs to be around 150-200 ft/lbs not 20. And a l/s works better in lighter vehicles than heavy ones due to the weight of the vehicle overcoming the friction of the plates.
on
If Ford still builds the Trac-Loc like they used to then I can help you guys. It seems they stack the friction and pressure plates in an odd order which can't possibly provide much traction, it's clearly designed to limit chatter and tire wear on pavement where 99.9% of these vehicles spend 99.9% of thier time. What I have found is that they stacks 2 steel pressure plates together with 1 friction plate seperating these double pressure plate pairs. As you can imagine 2 steel plates immersed in oil don't provide much grip. I have re-stacked the clutch packs in my trucks with a more "normal" order.. alternating friction and pressure plates.. and the diffs worked as you would expect afterwords... 2 tires driving all the time, lots of tire chirp on-road if powering through a tight turn.
7.3stroker2215
03-30-2022 11:58 AM
carl2591
07-09-2017 05:21 PM
Tectron1
04-10-2015 10:54 AM
68fordf100v8
08-14-2012 10:51 AM
