19.5 tires what do you think???
2000 F-450 4X4 7.3L Auto Trans Stock as they come.
I am in need of new tires for my truck. My truck is used for pulling a roll-off dumpster trailer so I am in and out of the landfill often (mud, re-rod, nails, lots of bad stuff and more mud). The tires that I have are 225/70/19.5 with a highway or on road tread. I will probably stick to the same size but would like to know what you guys think as far as brand and style. Would I be better off with "all around" tires or with steer tires on the front and drives on the back?? I know that an "all position" tire on the front would give me better traction in 4x4 but I don't want to lose steering control on ice and rain.
Any ideas are always welcome.
Tim
Tim
I recently re-tired my F-550 a couple of years ago with the same size tires. Be prepared for sticker shock.
My wife's cousin own's a couple of tire stores in the Corvallis, OR area and he told me that Michelin are the ones that give him the least amount of problems.
They are also some of the most expensive.
Don't get the straight highway tread like I made the mistake of doing. They tend to follow the cracks in the road. Stick with the all-weather, all-around tread and you'll have the best of both worlds. That's what I am getting next time.
Originally Posted by UP_There
I wasn't even aware that tires came in a 19.5 size! I have seen 19's.....but never 19.5. Sounds like a ploy to charge more for tires to me
Originally Posted by poorfatkid
So no one thinks that I will have a problem running a non-steer tire on the front? Anyone have experiance with re-treads on the rears? I have good cores but I have never had re-caps. Any thoughts?
Thanks for all the replys
Tim
Tim
Re-caps are a lot cheaper, but also a lot more troublesome.
Choice is yours.
A recap on a virgin core that you know the history on isn't to bad if the outfit doing the recap is good.But I really wouldn't rotate recaps on to the steer axle and you need to keep the air press. checked reg. I know it's not the same but on my dually I run 6 allterain tires they are 10ply 16" and I have no problem with the steers I have them rotated every 5,000 miles.
the KRD02 Kumho is what i run on all 6 tires. I've been very pleased. check this link. pricing was very good compared to most also. Barney
http://www.kumhousa.com/tires/commer...ck/regional.do
I think for your usage I'd look at more of the on/off road style. You can go to the Michelin website and see all of the tires and what they're designed for. In a commercial tread like that the terminology is a little different than you see in a LT tire. Drive axle, Regional tread . .. things like that but you can pretty much figure it out just by reading.
FWIW, mine are, on their site, listed as regional drive axle radials. They work just fine both on and off road, and by off road I'm not going to Tahoe just construction sites. But we've got a good mess of snow and ice at the moment and they're great on that too.
You might get sticker shock but another way to look at is is lifetime of the tread. You've got a truck that needs an E rating and you buy something with an H and a load cap of 6500lb each, they're not going to wear very fast. Mine came with 21/32 of lug and here we are about 15K miles later and I havent lost 1/32 of it yet.
Tim
Tim
I alway run all position on all my trucks
