Replacing Broken Fog light with OEM???
If you can stick your hand in between the fogs with a ratchet you could do it that way......only 3 (?) bolts hold the fog light assembly in place.
Not sure if pulling the grille would give you better access or not....
The bumper is very easy to remove.....even using handtools you will have it off a few minutes.
Thank for all the responses
Aldridgec: You hit it right on the head. I took off the grille and that’s no help.
I can't get the fog light through the slot in the bumper so I’ll try taking the fog light off the bracket. Do you know if the clear lenses cover comes off the fog light as I tried taking the old one apart with no luck?
By the way I already replaced the bumper and grill because of a collision and didn't have the fog light I needed than.
Thanks
Thanks
