wife started up the truck tonight at work,pulled on to the hwy! runnunig fine then theres a loud KNOCKING sound comming from under the hood,with enough smoke comming out of the tail pipe to close down the hwy! zero visability thats how bad it smokes! and knocks bad too i had to go get her so i started the truck wasnt easy to do! any ideas? ps had it towed home dont need broken windows too!
ok i was able to get to my turbo wheel tonight! when i grabed the shaft and tried to move it back and forth it didnt move,but if i go up and down or left and right i get some play in it, very small tho! so what ya think?
you will have about .001 to .002 up and down side to side play in the wheel..but no more then that..the oil will tighten it up when its running... sounds like you have some thing in the bottom end that let loose...
