OT -- HELP!!! I Can't Get Hot
#46
#47
Well, It Sunday afternoon and I didn't work on the little Falcon at all. I just had too much other stuff to get done. I got it where its putting out 135 degree air out of the vents and the little woman is happy (so far). Its still not quite right but at least now I have time to mess with it, its not such and emergency.
Christopher, great suggestions. The Falcon does not have the water control valve in the heater hose. It always circulates through the heater core. When you move the Heat/Cold lever it moves a door to adjust how much air is directed through the heater core. I adjusted the air mix door, defrost door, etc. I don't know if it has a arecirculate function but that is a great idea. I'll look into it as that would sure help to run some already heated air back through the heater core. Good thinking!
Thanks
Bobby
Thanks
Bobby
#48
Received 1,353 Likes
on
quakerj
12-24-2014 12:43 PM
