camshaft positioning sensor
i need to know the correct installation of the sensor on a 94 4.0. i cannot find this info anywhere! i have the tool, but need to know at what degrees the crank needs to be set at before installing the sensor with the tool. also at what position to install the sensor.i tried to get this info b4,but did not recieve the correct info.thanx in advance for your input.
