Glow Plugs ??? 35 degrees
Pacific N.W. diesel owners.. ( and anyone with answers )
Hay guy's maybe you can help....I have a 2000 F-250 w/97,000 miles ...... I have had problems in the morning's when it's around 35-36 degrees and below....truck cranks over but no start....I replaced the CPS a couple months back ,and replaced bolth batteries a month ago thinking that was part of my problem , I guess not cause it still won't start without either pluging it in or haveing to let the plugs warm up 5-6 times before finally turning over .
Do I need to replace my glow plugs.........?????? ........is this something I can do myself easaly ??????...... any and all info helps...... THX guy's ....... A.
I am thinking that your relay that triggers the glow plugs may not be working correctly. Next time this happens- Find the rearmost of the two relays, sitting on top of the passenger side of the engine valley, in front of the compressor manifold. Use an insulated screwdriver to short the two large lugs on the relay together. You'll know you got the right one, because on one side of the large lugs, a ring terminal will split into two wires, one yellow, one brown. That goes to the injectors themselves. Do this for 20 seconds with the key in the on position, and see how she starts.
sammydiesel13
15
10-16-2012 08:13 PM
loudmusic88
10-10-2009 10:06 PM
