This one is for you suspension gurus
Well I got a really good deal on a Superlift 6" suspension lift for my truck and I didn't really see what all it was missing. Now I'm missing two pieces. Here's a picture of the two things that I'm missing: The problem is that I don't know what the things are so I can't order something if I don't know what it is? According to the parts list, they are either: front anti-sway bar drops or compression travel stop extensions... Which one is it? I thank all of you on FTE in advance. Also anyone know where I can get some U-bolts made for cheap?
Those are spacers for the bumb stops. You can build your own or call up Superlift. (P/n 55-06-9660)
They can also supply you with the right U bolts.
Front U-Bolt 9/16X3X10.5 and 9/16X3X11.5 (P/n 11902 and 11942)
Rear U-Bolt 5/8X3-7/8X18.5 (P/n 11922)
They can verify the numbers but they should be right
Take some 1x3 tubing and cut it to 5" in length. Drill holes on one side that match up to you frame where the existing bumb stop fastner holes are. On the other side drill a hole in the center for the new bump stop. Also if you drill a hole opposite the hole for the bump stop that fits a socket it makes it easier to tighten.
Edub, this is where i've bought a few sets of u-bolts from. Awesome stuff and really low priced too.
http://www.stengelbros.com/U-bolts.htm
JacoFordCummins
Engine Swaps
45
11-04-2020 09:09 AM
4dfan
1999 to 2016 Super Duty
10-05-2011 11:14 AM
skunk250
10-05-2008 03:12 PM
