Edge Programmer
Old Dec 6, 2007 | 08:23 PM
MikeK321's Avatar
MikeK321
Edge Programmer
Wanting to know how I can program my new Edge Evolution Programmer for optimal fuel economy and performance? I don't know how or what the perimeters are without messing the timing up or getting bad gas mileage. Would like the correct numbers to do this and any other helpful tips. I drive a 2004 F-150 XLT Screw 4X4. Currently have a 2 1/2" leveling kit installed, MAC performance air intake kit, running 285/70/R17 Bridgestone Revos. Also, having trouble figuring out the right calculations for that tire size in mm. Thanks for your help
Mike
Old Dec 6, 2007 | 08:45 PM
mattd17's Avatar
mattd17
to set for your tire size, you need to set it to 2610mm. if you want to set a custom tune, then it depends on which octane fuel you are using. level one and two are designed to run on 87 octane, and level 3 is designed for 91 or better. now, if you run higher octane than the 91, you can increase your timing by .5 degress for each octane higher than 91. of course, if you notice pinging or detonation, then you should bring it back until it disappears.
Old Dec 6, 2007 | 09:21 PM
stratus225's Avatar
stratus225
I have tried farting around with the timing settings and others on mt Edge and have found that the programmed settings on each level seem to work the best, but then again I havent installed my CAI yet either.
Old Dec 7, 2007 | 10:04 PM
Frank'n'Ford's Avatar
Frank'n'Ford
17"=431.8mm
Old Dec 7, 2007 | 11:55 PM
mattd17's Avatar
mattd17
Originally Posted by Frank'n'Ford
17"=431.8mm
this may be true, but the setting that he was looking for is a calculation of:
1.) Multiply width x ratio x .02
2.) Multiply rim x 25.4
3.) Add steps 1 & 2
4.) Multiply step 3 x 3.1416
the result is the circumference in mm
this is what needs to be entered into the edge unit for it to correctly calculate the actual speed.
Old Dec 8, 2007 | 09:21 AM
sysman_rick's Avatar
sysman_rick
Post
Mike
I would keep checking this thread for tuning suggestions. There are scores of folks out there with custom settings. I believe there some tumers who offer
a customized tunes for your specific vehicle.
97 HD
2004 - 2008 F150
Aug 2, 2012 07:45 PM
OptimusF150
2004 - 2008 F150
20
Aug 15, 2010 04:52 PM
boots1219
6.4L Power Stroke Diesel
Mar 16, 2010 08:03 PM
jdhudall
1997 - 2003 F150
Oct 26, 2009 09:12 PM
74redone
2004 - 2008 F150
Sep 20, 2009 06:42 PM
