6" bds lift for 95 f150 - Ford Truck Enthusiasts Forums
Old 12-03-2007, 10:07 PM
ackack
ackack is offline
ackack is starting off with a positive reputation.
95 f150 5.8 supercabthinking about installing a 6" BDS lift kit with extended radius arms. anyone have any experience wiht this kit? Suggestions? Problems? Other kits? Any info appreciated. Thanks
Old 12-04-2007, 12:16 PM
ToughBuiltFord
ToughBuiltFord is offline
FTE Sponsor
ToughBuiltFord is starting off with a positive reputation.
Old 12-04-2007, 05:47 PM
bocephus_3349
bocephus_3349 is offline
bocephus_3349 is starting off with a positive reputation.
this is a very sweet system.
http://broncograveyard.com/bronco/i-...adius_arms.htm
I have a buddy with this set up on his 71 ford. The radius arms on this lift will add allmost 2" up front. they mount about 8-10"'s behind stock. The kit is a littly $ if i did mine over this is the way id go. I run skyjackers 6inch system on mine right now. To even make it better go with
http://broncograveyard.com/bronco/i-...o_f150_4wd.htm
just my .02
Old 12-04-2007, 06:16 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
I am in the middle of doing a frame off rebuild of my 84 F150 4wd (same suspension as your 95) and I am using the Superlift 6" kit that bocephus_3349 is showing from Bronco Graveyard. The rear lift was pretty straight forward, full 6" lift with no blocks. The front was a bit more involved, not difficult though. You have the 4/6" TTB drop brackets for the axle beams and radius arms. Getting the frame rivets out can be a PITA laying on your back... I believe I have mastered this. Rather that using the stock radius arms I opted for the Super Runner extended arms. In doing this you reuse the stock radius arm brackets and move them back 18". I ran into a problem with the brackets interfering with the transmission crossmember. Superlift offers an adapter bracket to solve this problem, I modified my trans crossmember to work with the brackets instead. The job has been conciderably easier for me because I am dealing with a bare frame... no engine/trans, no body, etc. If you are going to run your truck off road hard, many lift kit manufacturers recommend stitch welding the TTB brackets to the crossmember. I did one further and added steel plates to the areas where the bolts go through the crossmember to reinforce it and prevent stress cracks. Hope this helps!
2012 F250 6.2
1999 to 2016 Super Duty
22
04-04-2013 11:01 AM
jojolimited
Offroad & 4x4
03-03-2012 07:02 PM
TYZ78F150
06-05-2011 03:03 PM
gloorm
05-23-2009 10:49 AM
ackack
12-02-2007 10:37 PM
Quick Reply: 6" bds lift for 95 f150
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
