ever heard of a morr ride suspension?
has anyone ever heard of a "morr ride" suspension? it is some kind of rear suspension system that uses rubber shear plates in the rear spring mount. does it work?how does it hold up?i did find the website but can't get any real life data on it.thanks for any help.
I know these guys. Very good company. Their suspension system is about the best you can get for a trailer. The adaptor for the 5th wheel tongue takes out a bit of the shock. It works well with our TrailerSaver 5th wheel hitch.
I'd highly recommend them.
Ron Estrada
Hensley Mfg., Inc.
Ron Estrada
Hensley Mfg., Inc.
this system was on the truck rear end.we ended up buying the truck from classis chassis, it was a 2000 f350 2wd cc lb 7.3 at @120k.i drove the truck back a couple of hundred miles and it did help the rear end ride a little. i believe it will really make a difference with a trailer.thanks for your replies.
Well, after 197k miles/8yrs on the road, switched over to their "IS" system (independant suspension) and elect-hyd disc brakes. Amazing. Should have done it upon hitting road had it been avail back then.
Super company, excellant customer service & installation
No more broken springs, worn spring hangars/bolts. (No, I'm not overloaded)
Just alot of miles on metal parts
http://morryde.com/
http://morryde.com/
ufvj217
11-14-2016 03:39 PM
makthenif
1997-2006 Expedition & Navigator
11-21-2011 02:48 PM
browntown3
09-26-2011 06:25 AM
