Chatham County Here
Chatham County Here
My wife calls her the other woman
I call her my LiL Hotrod.
I just got a nice set of aluminum valve covers " powered by ford " off ebay and was able to sandblast them, they Look really good can't wait to put them on. Next change will be in the cam and lifters. But thats gonna have to wait till the summer. Have you done any mods to yours?
1973 F100 Long Bed ( Red )
302cid
Edelbrock 600cfm #1406
Edelbrock Intake #2121
Dynomax Long Tube Headers
Dynomax Super Turbo Mufflers
K&N Filtercharger 14"x3" Air Filter
Accel 8mm Plug wires
Accel Super Stock Coil + Cap
Mallory unilite breakerless Electronic Ignition convertion kit
Cran Cams Vacuum Advance
Auto Meter Gauges
302cid
Auto Meter Gauges
Chatham County Here
the truck is stock, except i lifted the front a little to put 33's on it. it has the originol autolite 4 barrel on it. the carb is warn out. i'm going to order a edlebrock carb & intake sometime this week. (i hope) i also am working on how i can get the truck up in the air more. with the twin i beam front end, i have little options. i hope to have new brackets that are lower to keep the i beams and pinion arms in the same place..? then all i need to do is mod the stearing, which i hope i can make something off a highboy work. i don't know though, i am kicking it around. thats what i get for wanting a 4x4 look with a 2wd.
Chatham County Here
Yupe thats what I have heard around here, That its a pain to make a 2wd into a 4x4.
I raised my trucks rearend up two inches and stuffed some new Firestone Indy 500 Tires and Rancho rs5000 shocks on all four corners. Rides great! Except she does drift alittle now and then. Going to be replacing all the bushings maybe this summer.
One little bit of advice... make sure you drain the coolent out before you go and pull off that old intake. Lets just say that I didn't and almost paid for it. ( milk shake )
Have you found any good yards around?
Steveeno
11-22-2014 07:38 PM
1973FordF100
10-28-2008 02:05 PM
