272 bent pushrod
Old 11-30-2007, 12:18 AM
56efffie's Avatar
56efffie
56efffie is offline
272 bent pushrod
Everything seems to be getting oil up top but I still have a noticeably loud tapping coming from one of the valves over the #1 cylinder. It just so happens that the exhaust pushrod is slightly bent (wobbles a bit when I spin it) would this cause the excessive tapping noise im hearing.
Old 11-30-2007, 07:07 AM
312's Avatar
312
312 is offline
if its bent you will have valve noise.you should get another pushrod.
Old 11-30-2007, 11:25 PM
56efffie's Avatar
56efffie
56efffie is offline
thanks, I will have to replace it and see if the noise goes away. Are these something you have to buy as a set?
Old 12-01-2007, 09:09 AM
matt2491's Avatar
matt2491
matt2491 is offline
Not necessarily but you might as well.
Tinytune812
29
02-22-2017 04:25 PM
SwOkcOffRoader
04-02-2016 10:07 AM
ford141
03-03-2013 12:19 PM
poboy
07-18-2006 06:50 PM
alwig
1978 - 1996 Big Bronco
03-12-2006 08:13 PM
Quick Reply: 272 bent pushrod
