Trubo / Throtle ?
Old Nov 29, 2007 | 07:02 AM
Rich in CO's Avatar
Rich in CO
Trubo / Throtle ?
When I punch the throtle my truck bogs down or kinda stalls a little before the power comes on. It does wheather I'm going from a stop or rolling onto the freeway or passing.
what is it and is there any cures?
Thanks
Rich
Old Nov 29, 2007 | 07:25 AM
bdrummonds's Avatar
bdrummonds
There is a bit of turbo lag that is inheirant in the PSD. On the other hand it almost sounds as though you may have a boost leak, fueling problem or even may be the altitude.
What do your gauges say.
Old Nov 29, 2007 | 07:36 AM
mueckster's Avatar
mueckster
Has this always been a problem or it is it a recent one?
Old Nov 29, 2007 | 09:35 AM
WonderDonkey's Avatar
WonderDonkey
TPS maybe?
Old Nov 29, 2007 | 05:13 PM
Rich in CO's Avatar
Rich in CO
The guage readings are fine EGT's are in check towing & not towing boost up quick and tops out around 17- 19lbs where it always has with both tunes I have had on the truck.
I have always had a small amout of lag, but this time around it seems more noticeable. I think I really noticed it once I installed the ATS housing, but not positive. I have checked for leaks, but not with a leak detector, the up pipes are clean not soot, and no play, both O rings where installed on the ATS.
What it TPS?
