Help! Broke fuel line
Upon pulling into my driveway I smelled fuel. I stopped truck got out and noticed that on the right side of the fuel bowl there is the ( I think )incoming fuel line attached with a brass fitting. I touched it with a wrench to tighten it and it broke the second the wrench touched it. The housing where the fuel inlet comes in broke off inside the brass nut. The housing is busted. I called all over town and nobody sells this part. Is this an International only part, a Ford only part or what? Need some help everyone, truck is stuck in the driveway and if I key on fuel sprays everywhere. Thnaks very much in advance, I'm sure after a reply or two I'll be set as usual.
was it this piece? if so Diesel innovations has them, or, like Kris said I have a spare and would be happy to give it to you, but I am also on the eastern side of the country, so you would have to wait a few days.
OBTW, it is called the fuel pressure regulator housing, and inside there is spring loaded poppet valve. I bet the fuel line is o.K. just unscrew busted housing from it and get a new compression sleeve for the line when you get a new housing.
You need International Part number 1831296C92 It is a flex fitting sleeve kit with new seals for all of your hard lines about $12-15 form INT. (these are just the little black bushings that go inside the brass nut on the hardline. do not skimp on this part or you may have leakage develop soon.
Originally Posted by weekendwarriorfsw32
I know this is off topic but how do you find a international parts delarship. I went on to google and cant find one.
Thanks,
Nick
Thanks,
Nick
