Sponsored by: Real Truck
Back spacing?
Old Nov 26, 2007 | 06:06 PM
arno's Avatar
arno
Back spacing?
On a stock 05 with 17 inch alloy wheels.
Old Nov 26, 2007 | 06:20 PM
MattyNJ's Avatar
MattyNJ
5 1/2"....
Old Nov 26, 2007 | 08:17 PM
arno's Avatar
arno
Thanks. If I go to a 10 inch rim what back spacing will I want to maintain, 5 1/2?
Old Nov 26, 2007 | 08:19 PM
MattyNJ's Avatar
MattyNJ
that depends on how far you want your tires to stick out....
Old Nov 26, 2007 | 08:25 PM
arno's Avatar
arno
How much back spacing can the truck handle? I dont want the tires to stick out much past the wheel well, only an inch or so.
Old Nov 26, 2007 | 08:30 PM
MattyNJ's Avatar
MattyNJ
Give me more info: what size rims & tires are you getting? is the truck lifted? how high?
what are you trying to do to the truck?
Old Nov 26, 2007 | 08:35 PM
arno's Avatar
arno
The truck is not lifted. I previously had an 02 with 10 inch rims and 295/75/16's. I loved the looks and had no clearance problems. Now I have hte 05 and cant run the 16's, but want a similar set up, tires and rims. I dont recall what the BS was on my 02 however.
Old Nov 26, 2007 | 08:39 PM
MattyNJ's Avatar
MattyNJ
So why not just mount bigger tires on your stock rims???? Throw some 33's on there.
Old Nov 26, 2007 | 08:43 PM
arno's Avatar
arno
I dont want the balooning with a 295 or a 305. The 10 inch rim allows the tire to sit perfectly. Or 9 inch rim I guess.
Old Nov 26, 2007 | 08:45 PM
MattyNJ's Avatar
MattyNJ
the 17's are 7.5" width. Good luck
Old Nov 26, 2007 | 08:49 PM
arno's Avatar
arno
So no idea what the max back spacing is?
Old Nov 26, 2007 | 10:44 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Factory backspacing is 5.80". You would not want anything more than 6" or the tires are too far in.
If you do not want to stick out too far, a 9 or 10 inch wheel with 5.5 - 6.0" backspacing would be ideal.
Old Nov 27, 2007 | 09:02 AM
arno's Avatar
arno
Thats the info I needed, thanks guys.
Just to be sure, a 305 in a 17/18, will fit under a stock truck correct? No lift?
Old Nov 27, 2007 | 09:53 AM
killaford's Avatar
killaford
i run 10" rims with 6" backspace. i think you can run 6.5" or so but finding a 10" rim with that spec will be hard.
if you find something 9" wide with 6" backspace your in good shape.
Old Nov 27, 2007 | 10:52 AM
arno's Avatar
arno
Perfect, thanks. What wheels and tires are you running?
