I started my 96 PSD this morning at about 34 degrees. I let it warm up for about 15-20 mins. when i took off the turbo and exhaust pipe were makin a wierd sound, almost like there was something stuck in the pipe. wasnt a whistle like normally on my straight pipe, but more of a blowing sound like an air compressor valve being opened. when i was goin about 25mph it was doin same thing and untill i stepped on it a little more the turbo made the normal whistle sound like normally it does but after i let off it started to whoooosh again. is it a problem with my hpop to the turbo or is it my ebpv??? or is it another problem??
Its not a problem, its a built in valve to increase EGTs at idle/low speed to warm the engine up faster, they generally work, but can get annoying like that
The valve does very little of what it was designed to do. If it malfunctions and stays closed it will cause low power and high EGT which could hurt the engine and turbo. The valve only aids in cold start up warming not operating temps.
