Cold weather problems
Old Nov 24, 2007 | 08:58 AM
Harley320's Avatar
Harley320
My 2000 EB Expy 115K miles has developed 2 annoying problems that only happen when the weather gets cold. First the gas pedal becomes very difficult to press almost feels like it's stuck once you do get by the initial stuck it is ok until you start from a stop again and it does this all day long. Maybe I just need some WD 40 on the linkage?
The second thing when I start my Expy and it is cold outside my oil guage reads 0 and my oil light is on this last until the engine warms up with the guage bouncing between 0 and normal pressure I think this might just be a faulty sending unit since the oil level is normal and my motor has made no noises and seems to run just fine while showing no pressure where is the sending unit and how hard would it be for me to change it..
Thanks for your help
Old Nov 24, 2007 | 10:17 AM
bigblock_drock's Avatar
bigblock_drock
1. i wouldnt spray wd-40, but maybe some carb. cleaner or something along those line.
2. i would think maybe the sending unit also, but maybe someone here will verify
Old Nov 24, 2007 | 11:48 AM
c_hohensee's Avatar
c_hohensee
As for your first problem I suspect you need to clean your throttle body. Take off the duct leading to it and spray the cleaner around the butterfly at the edges. Use only throttle body cleaner as there is a teflon coating you need to be careful of. The second problem sure sounds like a bad sender.
Old Nov 28, 2007 | 03:57 PM
volkspower's Avatar
volkspower
Trailering
Mine's doing the same
My 01 F-150 does the same. the oil pressure lite comes on only when it's very cold (37 or below F) outside. After a few minutes of running the needle jumps from rest to more than half the scale. I'm figuring its a sensor issue. I'll look into it this weekend and report.
Old Nov 30, 2007 | 09:09 PM
gherrick's Avatar
gherrick
I clean the throttle body 1x per year. I spray some throttle body cleaner on the surfaces and use an old toothbrush to clean the walls and the throttle plate itself. Keep the throttle operating smoothly.
Old Dec 1, 2007 | 09:31 AM
Modified 99's Avatar
Modified 99
What weight oil are you using? Consider using a 0W-30 or a 5W-20.
How cold is COLD?
Changing the sending unit may be the ultimate fix.
Old Dec 1, 2007 | 01:35 PM
Harley320's Avatar
Harley320
I am using 5W30 and it starts to happen as soonas the temp gets down to about 40
Old Dec 1, 2007 | 07:20 PM
bucktaylor's Avatar
bucktaylor
My 01 does the same thing, I'll try cleaning the TB and see if it helps.
Old Dec 1, 2007 | 08:05 PM
tykateexcursion's Avatar
tykateexcursion
i had the pedal problem and used 3m throtle body cleaner. you have to spray it into the throtle body and let it sit. Read direction on can. As far as the oil we had the same problem also you will need a new oil pressure sending unit the parts not to exspensive but the labor will hurt. It is awkard to get to laying on the ground but not bad if it is on a lift.
food luck
Old Dec 3, 2007 | 10:44 AM
volkspower's Avatar
volkspower
Trailering
New oil press. switch
Installed a new oil pressure switch. That fixed it. $8 at Autozone and 30 minutes later I was done.
philv
Jan 1, 2017 10:31 AM
helomech
Dec 17, 2016 09:43 PM
Frmnsal
Aug 5, 2016 08:25 AM
Rocketattack
Apr 25, 2016 09:00 PM
Goinnuts
Dec 2, 2015 03:12 AM
