95 Explorer Lift kits?
Old 11-22-2007, 06:25 PM
Crazed1122's Avatar
Crazed1122
Crazed1122 is offline
Ive been serching and i havent been able to locate a lift kit, body or suspension, anywhere for a year 95 explorer. i have found kits from up to 94 and from 97 and up but nothing in between. Any quidence or advice would be greatly appreaciated.
Thanks!
Old 11-22-2007, 08:51 PM
shiloh66's Avatar
shiloh66
shiloh66 is offline
Crazed, to my knowledge there are only a couple of companies that make suspension lifts for the 2nd generation explorers,and they are pretty pricey.Somewhere around $1500 dollar range.Most folks go with a 3 inch body lift made for a Ranger pick-up.They work very well( I have one on my 98 Mountaineer), with the exception of the bumper re-locate brackets. The front will work with some shimming, but for the rear you will have to make your own. I also raised my torsion bars and gained about an inch and a half in the front. I added an add-a -leaf in the rear spring pack to get it even with the front.
Old 11-22-2007, 09:01 PM
460's Avatar
460
460 is offline
It seems like I remember reading somewhere that the torsion bar crossmember, which needs lowered when you lift an IFS rig, is welded to the frame which is why there are no suspension lift kits advertised for it. The Explorers after '95 have a bolt-on crossmember, making it possible to lower the crossmember when installing a lift kit.
I don't know anything about the body lifts.
Old 11-24-2007, 02:20 PM
Crazed1122's Avatar
Crazed1122
Thanks Very much ill have to look into the ranger lifts! thanks again!
Old 12-14-2007, 04:08 PM
mycam8u2's Avatar
mycam8u2
mycam8u2 is offline
hockey pucks work well for body lifts
Ford_or_Nothing
13
08-05-2011 05:24 AM
Explorer Freak
01-10-2011 10:45 PM
sathb
11-14-2001 11:55 AM
Explorer_X
10-16-2001 04:32 AM
etobolski
09-10-2001 10:38 PM
Quick Reply: 95 Explorer Lift kits?
