Considering 2008 F250 4x4
Ok guys i am considering the purchase of a 2008 F240 FX4 crewcab and wanted to know if it would be better to buy it with ESOF (electronic shift on the fly) or just leave the option out and have a manual 4x4 shifter. Also where would it be mounted for the FX4 with floor console. And if i get the ESOF would i still have to deal with manual locking hubs?
I go manual hubs and manual transfer case.
All you need to do is lock your hubs if you think you may need 4 wheel drive anytime during your trip. SOme guys up here in the north country leave their hubs locked all winter. When you need 4 wheel drive all you do is pull the lever back one notch.
The level will be on the transmission hump, on the far left of the hump but within easy reach of the driver. The "console" does not project out much beyond the front edge of the front seats.
Originally Posted by RedDragon777
.....if it would be better to buy it with ESOF (electronic shift on the fly) or just leave the option out and have a manual 4x4 shifter. Also where would it be mounted for the FX4 with floor console. And if i get the ESOF would i still have to deal with manual locking hubs?
My ESOF has the AUTO/LOCK hubs. The AUTO means that it will do whatever the dash switch is set to. LOCK just locks the hubs but does not do anything for the transfer case. If the vacuum hubs go out, then there is obviously at least a back-up plan. If the transfer case motor goes out, then you are screwed. Also there are fuses, relays, wiring..... way too many possibilities for failures.
I dont know about the FX4 question.
Problems with ESOF
Problems with ESOF....
It does sound crazy but I try different things and mine will work too, whereas it wouldnt before. In bad weather (snow/ice) situations you are willing to do ANYTHING to get it into 4WD; stand on your head, jump up and down, run in circles, etc. With this in mind, I thought it would be cool to start a poll: https://www.ford-trucks.com/forums/6...l-or-esof.html
Originally Posted by stevenn1
....10-20% of the time mine does not want to go into 4x4....without a little bit of babysitting....I know it sounds crazy but I try different combinations and it eventually works...
Well, I will give my 2 cents in favor of ESOF. I have an early 99 F-350 that I bought in April of 98, so it's over 9 years old and over 100k miles. My ESOF has worked perfectly, and I use it almost every week...but maybe thats why. I live in the desert with dirt roads and sand everywhere. I never wait till I'm already stuck, because if it even looks like I might have trouble I just turn the switch and it locks in about 1 second later, if that. It's great for the wife also, I have an early Bronco as well, and she just can't figure out the whole lock in the hubs, fight with the lever to get it in, back up to take the bind off everything so it will come out process. With ESOF just a click either way and you're done.
Originally Posted by MattyNJ
never heard of the f240 ...is it the diesel?
Well i guess everyone loves having the manual t-case, is there anything i should know about using a manual t-case and by the way this will be a 6.4l Diesel and will come with tow command and auto trans (truck will be used for towing, hauling, and recovery vehicle)
well the only reason i went F250 is because there is no difference between the 250 and 350 SRW in towing it is only when you jump to the F350 DRW that towing increase a little. Really i first wanted an F450 but money is not on my side when it comes to getting one so i will stick to the F250. Plus i do not have room at my house for a DRW truck
for the duties you listed, i would most definetly go with the f-450!! you get higher tow ratings, and much heavier payload ratings as well. another nice feature is the 19.5 inch wheels (think UPS, Fedex, etc.). you can run tires for far more mileage than the 17",18" or 20" that come on all of the other trucks. if you were to upgrade to a set of Rickson 19.5" wheels for a F250 or f350, that would run around $2000 for aluminum. that's without the tires! i'd scale down on the luxury items or trim level to get the f-450 if money is an issue. they are truelly not that much more expensive.
