A doggy truck.
A doggy truck.
I have a 97' F-250 460efi supercab short box, that supposedly belonged to the state of SD. I bought it from a dealer that said it was from SD and it is in good shape, so I bought it about a year ago. I geuss I just never noticed it untill now but when I power brake it, it wont spin the tires, it is only moteraly quik from about 0-30 untill it shifts into 2nd then it is a dog. From about 30 to 95 it is so slow that it is almost funny. I have done no modifications but you would think somthing that gets 8mpg would have a little more go to it, or at least I think so. Is this normal for stock and what quick cheap things can I do to free up some power.
I had a similar problem on my '97 F350, same motor, it would bog pretty bad when under a load or when trying to accelerate fast. When it bogged, the engine sounded really choked up like it had something really restricting the air flow in the exhaust.
I took a look inside the catylitic converter and that was the problem. there was all kinds of buildup and crap from the engine that accumulated over a long time. So i replaced that with a new aftermarket cat, and while i was at it threw on a Flowmaster cat-back system and that helped a ton. Now my truck pulls better than ever, even up big hills pulling a trailer and carrying a big load. it has great response and gets up to speed pretty quick with no hesitation
dont worry about back pressure if your leaving your stock exhaust in, get rid of your cat and replace the stock muffler with a flowmaster. Those are cheap fixes. a expensive power gain would be long tube headers and cold air intake, and a chip. You may also want to look into your engines tune up status, it may be time to get in there, and change plugs, wires, distributor cap, filters, ect...
