I need a Y block bell housing to install a 292 into a 60 Ford 100. As I am told, any 57 or newer truck unit will work. It must have the frame mounts and the mount for the clutch cylinder.
I have several bell housings for sale. One is for a 223 6 cyl, one is for a Y block truck w/o clutch cyl mounts (54-56) and one is for a pass car Y block.
B8C-7505-A .. Bellhousing ~ Fits 1957/64 F100/250 272/292 with a 3 speed light duty transmission.
Bill, I found a guy who claims his bellhousing will work. Problem is, it has a different part number than the one you gave me. Can you tell me what the following part number fits? TAAM-7505-B 950L.
Thanks!
Gary
Thanks!
Gary
That's not a part number, it's the Ford engineering number. Ford stopped stamping true part numbers on parts circa 1953.
