i'm having a number of problems. first of all every sensor on the engine seems to be bad, according to the OBD2 tool. and the a/c seems to be bad. i can't believe every sensor would be going bad all at the same time. i suspect an electrical problem. if i have a bad ECM would that cause the issues?
